I don't know if it's been mentioned to you but these lathes have a design issue . You can engage the power cross slide & the half nuts at the same
time , so keep that in mind . If you forget & if your lucky you will just destroy the brass key that is in the worm gear in the apron that slides in the lead screw groove . If your not lucky you can be looking for gears or a right side lead screw support . Most of the supports I have seen have been repaired . I need a new thrust bearing for the left side of the spindle for mine , but it's a bastard size & after a few yearts of looking I bought a bag of 3/16 bearings & will replace the bearings in the cage . When I took my spindle apart several of the thrust bearing balls were in several pieces . If you need any pointers on dissambling the head stock assy let me know .
animal
Regarding that worm gear, mine is brass and it seems like it doesn’t have a key way slot when I removed it. The ends have what seems to be a key way slot started however it’s smooth all the way through.I don't know if it's been mentioned to you but these lathes have a design issue . You can engage the power cross slide & the half nuts at the same
animal
It’s the worm gear that slides of the lead screw above the clutch worm gear. Do you have any more information regarding that worm gear by any chance?
