- Feb 1, 2018
- 1,862
I see Nelson linked the "Testing Machine Tools" George S book above. Those spec's in there are the ones Connelly based his spec on. The spec's in there are more complete too.
Rex, looks good. I didn't read it word for word....though.... Be sure to relieve the middle 40% of the slides approx. .001" so they don't rock. Be sure to lock the tailstock down when making the tests, That test bar in the TS quill is a bit long. I would also use some Phenolic between the TS halfs that is glued down. Good scraping you must have had a good teacher
Do you want to borrow it? I made 2 different sizes.
If you are anywhere near San Jose, I’ll definitely take you up on your generous offer.
How machinable is phenolic? Can it be scraped?
If I were you I would put it on a mill and indicate in the front 1/2 (the one you filed) and then kiss that side to be sure it is straighter then a filed surface,
Built a small one and a large one, and USPS is only $8 awayNice work! Mag base parts were a clever idea. Were you able to radius the inside edges of the slot in the C foot part? The only way I could figure out how to do that was with a custom ground cutter and somewhat tricky workholding and alignment in the mill.
If you are anywhere near San Jose, I’ll definitely take you up on your generous offer. It’s a fairly small 10” lathe. John York’s large Kingway is too big for my vees.
