- May 3, 2020
- 338
The cheapest way I can think of is using a sensitive level. Get the casting level based on the un-worn parts at either end of the ways, then use a level to measure tilt. If the level bears only at 2 points, you can scrape those areas down to level and use a much shorter reference surface to connect them. It will be a pain in the neck but a big project like this will always involve some trouble.
It would be nice to be able to cross check your work. At some point you will doubt everything and it's a real boost to the confidence if you can check another way.
There's a video of a guy doing some precision work using a bare camera sensor and a laser pointer. He set up the laser somewhere stable and moved the web cam along the rail. It was similar to an autocollumnator but cheaper and a lot more IT skills.
There's some other guy who cast a bunch of rails to fix up the bed of a lathe. It's taking so long that I lost track of what they're doing. I think that strategy would be the most expensive because you'll need a foundry and planer.
