He’s a good dude. Handy around the shop on the lathe, mill, TIG welder and angle grinder. He wants to be a mechanical engineer, so making sure he has a foundation in actually doing rather than just designing
Made a few more passes on the sole and the 45 degree face and in addition to getting a bit better through practice, two big improvements for me are:
1. I put a 600 grit diamond wheel on the Deckel clone and am now correctly grinding down into the carbide blade. I knew better, but in my excitement over trying out my jig, I had angled it 5 degrees the wrong way. The results are WOW. Super sharp carbide and a MUCH easier time scraping.
2. I added a better pad to my Biax/Dapra hand scraper and I wouldn’t have thought it would make such a difference, but it’s soooo much easier to body scrape now.
Another tip is to drill and tap 1/4" 20 holes into the ends so you can hold it better. Put in a hex bolt with a jam nut on it. Then tighten the bolts between to vises or 2 Johanson wood clamps. It will hold better and not wiggle in the wood V block.
I have the exact same casting and have also completed the milling on mine. Same results on the first hinging. I have not yet started the scraping process yet due to not having any good scraping tools or a way to re sharpen them. Good tools are always on my bucket list. Thanks for bringing us along.
