I have a bunch of HSS blanks but I really don't know what I'm doing making tools out of them. So I've been using AR Warner HSS inserts.
So I chucked up that piece of aluminum, faced it off and drilled a hole through it. I found a .500 reamer in the mill tooling I got and reamed the hole to size.
I needed a 1.5" diameter so turned it down to size. Ok now what?
I used the reamer in the hole as a guide, slid the broken pulley on the reamer up against the small aluminum piece in the chuck and steadied the shank of the reamer with the tailstock and a live center.
I loosened up my tool post and lined my cutting tool up to the angle of one side of the pulley flange then slid the broken pulley out of the way so I could cut one side of the new pulley. Did the same for the opposite flange.
Obviously not the best way to machine a pulley but it's working. I went back and forth to get it to proper size because my tool width would start to cut the opposite side at the wrong angle as I increased depth. Once I got the proper angle, width and depth it was actually a pulley. Woohoo. I even test fit the new belt. Holey moley maybe this piece will work.
So I turned it down so it was about the same shape as a single 1 1/2" pulley. I left the top flange a little thicker so I don't break it again. There's room.
I left the main section of the broken pulley in the 4 jaw so I put it back on the lathe to bore a hole to put the new small pulley in.
I basically used what I had. No blueprint. Just measured what I had and made it fit. Totally winging it.
I was going to try a .002 press fit but I was worried that I'd crack it. So I went with .001 and retaining compound. I used a soft mallet to knock it in.
I didn't do it yet but I need to pin it with a roll pin or something.
I think it's going to work. Man I can't believe I got so lucky.
