Made some progress today. Man it was all I could do to lift that main casting up on the base cabinet. That's a STOUT casting. I got most of the big parts painted and started cleaning smaller parts. So far I'm just using a hand wire brush, wire wheel on my bench grinder, WD-40 and brake cleaner.
I didn't want to pressure wash a couple of the castings because I didn't want to damage the metal tags. I brushed on some paint remover instead. I'll scrape off the paint tomorrow.
The gibs were pretty crusty. Old hard lube, some rust and a few scratches. I used WD-40 and a scrub pad to get them bright again.
You more experienced members may scold me for this but I used a thin metal credit card sized diamond hone to knock down any high spots on the gibs and ways. Just a quick check back and forth with some light lube.
What lube is recommended for the screws? Sorry if I'm not using the proper term. I have way oil and spindle oil I use for my lathe on hand.
Any suggestions for the numbers on the dials? Bare metal? Paint in the grooves and numbers? I have 60 year old eyes. I can use all the help I can get to make them more visible.
