- Oct 21, 2014
- 2,156
Ok, looks like 32mm dia, the nut looks like a about a 21mm and pinned on both side Prob taper or something. The keyway on the bottom of it is 6mm and the quill in 7 7/8 long front to back Has a hole in it that I am not sure what it is for, and did not measure it.
Ok looks like it is real good press or something to keep it from moving. I know they used taper pins all over on this thing.
You can see the pins on each side of the nut here.
Here you can see the keyway and the hole that I am not sure what it is for.
Here is the taper end
Here is a pic of the hole looks like a pin could go through it to the other side.
Maybe for holding the MT taper tang.
The ring area you see just behind my thumb is a small grove that goes round it, It comes out the front of the tail stock just before the screw disengages
Hope this helps..
Edit: mine is the PY but looks to be the same as the P that dat510 posted while I was posting mine.
Hope this helps..
