A few years ago, I bought a used G0709. I've occasionally been concerned about noise from the spindle, and today I was justified. Under nearly no load (slowly drilling a 7/64" hole) it suddenly sounded loaded, and when I turned off power, it stopped quickly and the chuck was hard to rotate even in neutral. Clearly a bad spindle bearing.
Looks like I have the exciting opportunity to learn spindle bearing replacement.
Edit: TL;DR of thread:
- Would you buy the $120 set of NSK bearings from Griz, or is there a reason to consider anything else? [Edit: I have already ordered them...]
- Has anyone who has been through this before willing to help out if I get stuck?
- If you've done this before, is there anything that I should know ahead of time? Consumables that should be ordered with the bearings? Tools that I'll need?
- Grizzly is shipping regular-precision bearings in boxes marked as precision bearings, and it shows. They are almost certainly legitimate NSK bearings, but regular precision and fabricated at NSK's plant in mainland China.
- Motion Industries can source precision bearings, @Cadillac reports about $400
- There are lots of pictures in the thread that might help you if you are trying to do the same replacement
- If you haven't already done this, 6x3mm neodymium magnets fit nicely in the oil drip channel that feeds oil to the bearings, which may help keep chips out.
- The internet is full of videos of changing spindle bearings in various lathes. After I watched those recommended in this thread, The Algorithm kept throwing more at me.
- You need large ratcheting snap ring pliers both for disassembly and reassembly.
- Comment #23 has a summary of the official Grizzly preload-setting procedure from the manual
- Comment #35 has a detailed textual description of the steps I used to put the lathe back together.
- Ultimately: The Grizzly replacement bearings are not as high quality as what was included in the lathe, so if you are doing this, buy quality actual P5 bearings through a reputable distributor such as Motion Industries. This is one of the more expensive components of the lathe, so don't be surprised when you pay for them.
