- Apr 13, 2023
- 258
I have 2 boring bars I want to remove the head from. One is a nice Criterion head on a sketchy R8 adapter, and the other is an Yugoslavian import on a good R8 adapter. I want to put the Criterion on the good adapter, and sell the other one to a friend who has a mill that takes a non R8 shank - the adapter will be his problem.
So, I can't get the head separated from the adapter on either one. I've tried putting them into the spindle, with the mill in low range and using a strap wrench. No luck so far. How else do you securely hold an R8 adapter? I'd rather not add much heat to the boring head.
And yes, they both appear to be two piece units.
