- Dec 20, 2012
- 9,408
Once again Mike , your informative write ups are priceless to the members on this site . I hope they realize the efforts you put forth on them .
Thanks, Dave!
My point, exactly!
This doesn't make sense to me but I'm an idiot. If your parting tool is on center then it will be pushed down and away from the work. I believe that the benefit is that the back mount is more rigid the compound. Lathes are designed to have the force pushed down on the carriage, not pulled up by cutting forces. I made a solid toolpost and my parting woes mostly went away (9x19 and 10 x 22 lathes). I am probably wrong though (see the first sentence of the post).As Mikey educated me on this awhile back on the front side the parting blade is forced down and into the work whereas on the back side the parting blade is forced up and away from the work. That's why parting on the back side works so much better than parting on the front side.
Now it makes sense. Thanks for the clarification.Think of a rocking motion with the fulcrum being the base of the tool post. As the blade is forced down there is a upward force at the outside end. This causes the tool post to lean into the work forcing the blade into the work. The opposite happens when parting on the back side. Here the blade is forced up which forces the outside end down. Now the tool post is leaning away from the work pulling the blade away from the work. We are only talking about a few thousands but that is enough movement to cause the problems with front side parting.
Thanks for the info @mikey ! Now that I have converted my Craftsman/Atlas 12" to the MLA A-11 cross slide( coupled with a solid plinth tool post was a quantum leap forward in rigidity ) I'm considering getting MLA's rear mounted tool post for parting and knurling. Just trying to wrap my head around the physics as to why a rear mounted tool post makes for more rigid parting, than the standard way? I've read too many accounts as to its effectiveness, so I'm confident that it in fact works.........just trying to understand why?
