- Jan 26, 2011
- 632
Is anyone having trouble with a RCBS universal hand priming tool? Parts do not line up. Can not prime Rem 223 w/small rifle CCI primers in the RCBS universal hand held, but can in the Lee bench press using the same shell and primer that did not work in the RCBS unit. The center hole in the body seems to be off and wearing the plastic primer feed insert by elongating the hole each time it’s used. The tool works with 357 mag which has a rounded corner on the primer pocket and the 223 is square. Sending it back will be a 3 week wait judging from my last order. I do like the tool if only it will work. If someone has a fix I would like to hear from you. See pics for offset pin.
Paul
Paul
