That's the easy way. Seems like a lot of people like the harder way! Or they simply look around to see the closest thing that might work, not necessarily the easiest way. But, whatever works is fine.I took my my in laws nasty cast iron pan and put it in the electric oven while it ran thru self clean.
Pan came out clean as a whistle. Then I went thru a reseason process.
oxalic acid... try bartenders friend and boil it off.I recently obtained a few used pieces of cast iron cookware,skillets and plain Dutch ovens,and I want to start all over again new with them.
I already tested for lead and they are negative.I want to get them down to bare iron.Ive used easy off and vinegar baths but I still have remnants of previous seasoning and such,I want to completely clean them and start anew as I said earlier.
I have a pressure washer and thought it would be a time saver to accomplish that goal.
My websearches have turned up everything from,"Sure,whatever dude",to"No,it will collapse into a black hole!"
Maybe not quite so dramatic but I think you get the idea.
Has anyone done this?
I'll most likely try one piece either way but thought I'd ask to see if there is a right way or wrong way to do it.
How bout the Laser rust remover gun. Only those trying to promote it think it is a good idea. LMAOIt comes down to either a physical method (like abrasion) or a chemical method -- high temperature oxidation, lye/acid etc. The method of choice completely depends on what you've got on hand.
There's a relatively inexpensive plasma cleaner, based on a microwave oven, that would do the job just fine. It's called a "plasma-preen". By relatively inexpensive I mean about $8K, not counting the vacuum pump. But nobody in their right mind would buy it just for the purpose of cleaning up a CI pan.
I'll bet they do . It probably removes household stains and improves your sex life as well....or so they'd like to claim!How bout the Laser rust remover gun. Only those trying to promote it think it is a good idea. LMAO
Invented by a Navy Seal who just got tired of seeing the public getting screwed, so he quit the Navy and started his own Navy and_______now is cleaning toilets with his miracle toilet stuff !I'll bet they do . It probably removes household stains and improves your sex life as well....or so they'd like to claim!
