- Sep 28, 2022
- 179
Thanks for the pictures of your progress.
Here are a few pictures of the tailstock to show some of the changes between the early model C and the late model C. You can see that Pratt & Whitney added rollers to the underside of the tailstock. These are like fingers of a steady rest. They sit in a blind hole with a spring on the back side and an allen screw adjustment. They don’t lift the tailstock off of the ways – just lift it enough to reduce the effort and help limit wear. I don’t think these would be too hard to add. But of course, the devil’s in the details.
I also included pictures of the tailstock clamping assembly. On the late model C, they went to a cantilevered 4-point clamp that with a cam action of the handle allows for exact duplication of force and force applied equally to all four corners. I think this was an attempt to make the tailstock more repeatable when moved.
You can also see the way wipers on the tailstock. These are the same style used on the apron. They are a double felt with a bronze outer wiper. The wipers are put together in two halves. I really like the design of these wipers and have duplicated it on my Pacemaker. I’ve included some picture of the wipers I made for the Pacemaker because I have pictures of those disassembled.
