Pratt & Whitney Model C 12x30 lathe
My motor is advertised as 1740 and to start out I'm going to run it at full speed 60hz and use the gears and if I need a speed in between I'll use the variable knob. I plan on using a handheld laser tach to verify the spindle speeds on both the lathe and mill.
While I'm STILL waiting for my motors to get back from the shop, decided to start knocking out some oil system items. First on my list was the sight glasses as one was deteriorated and half gone so I removed, cleaned/polished two and fabricated two and cleaned and polished the bezels. Not a hard job but time consuming. Three are aluminum and tapped right off but the apron one is steel and deeply and tightly recessed and was stuck in so badly I had to chip out the otherwise good sightglass and use a blind bearing puller to slide hammer it out. I didn't think it was going to budge as It took at least a dozen serious whacks before it moved at all. Three of the four had a white background painted on underneath for contrast and my first thought was to paint some white epoxy on there but then I thought about using a thin piece of white plastic and matching the holes up.
@tailstock4 I went back and reviewed and found what you posted about sightglasses.
I will sometimes paint the target area inside the sight glass with either epoxy paint or 2-part urethane enamel both of which are oil resistant. What I prefer to do is to cut the background out of .025 white plastic shim stock. Then I punch out the two fill and vent holes.
I'll definitely go the plastic route. I think it will probably last longer.
Looks nice!
On tailstocks restoration pictures I noticed that the one on the apron is different, looked like it needed the front cover removed to pull it, interesting to hear how you managed. Mine are covered in about 20 layers of paint, so could definitely use the same treatment. Love this inspiration, thanks for keeping us updated.
Looks nice!
No prob! Once I got the apron one off and cleaned it and the apron cover I.D. up it was a close clearance fit. If I had removed the apron cover first I think it would have caused me similar grief trying to get it off of the sightglass ring. Although, if you know you're going to pull the cover anyway it's worth a shot. The apron one is a thicker steel ring and because of the close fit doesn't give you any wiggle room to pry it free. On mine I replicated the lenses out of 3/16" lexan and used some felpro gasket paper. The two that were salvageable I used a 3M headlight restoration kit to clean and polish them. Let me know if you need more detailed picks, I haven't reinstalled them all yet.
I would love any/all pictures you could take. Its just the 4 screws? I had thought they might've been screwed in, with that aluminum ring going over the whole thing. Did you use the gasket paper between both the glass and ring, and the lathe and assembly? How is the 'glass' retained? I imagine this would all be pretty obvious once I take them off....
Took some more detail pics of the sight glasses for you. On my lathe, three of the four are recessed to allow a little oil in between the lense and the white background. The fourth, next to the chuck, is just a window I presume to see if the oil is pumping as it's right in front of a nozzle and is too high to be a level indicator. This one is a flat lense, no recess. The apron one has a thicker steel ring.
On all of them, the gasket overlaps the edge of the lens like this:
I decided to tackle the tailstock in an attempt to maintain some momentum and because I felt like it would be a fairly quick job. Othe than having a couple dings to dress on the nose of the quill it seems to be in great shape with minimal wear. After a quick degrease in the parts washer and a soak in Evaporust it cleaned up pretty good. I thought I'd pull the handwheels to start cleaning them up too since I need them off to get to the apron anyway.
