- Feb 25, 2021
- 3,271
For long term issues it does help somewhat to put a moisture barrier under the slab. Concrete is porous enough that some water will seep through if the ground underneath is damp, you may not get obvious water spots but you can still get some source of additional humidity.Thank you, I didn't think it would be a big issue, but then I ran across a comment where it mentioned poorly cured concrete could be the source of rust issues drawing moisture into the shop.
