It's cheaper than buying and arbor press and Dumont broach set? I think that's the only reason. Well, that was my reason.Hi, I've never seen this nor do I understand what or why this method is used.
Was referring to the angle that seems it weakens the rod.It's cheaper than buying and arbor press and Dumont broach set? I think that's the only reason. Well, that was my reason.
Yes, very interesting. Is the printout your notes or do you have a link to the source?I made a keyway broach, to cut a slot in an aluminum pulley I machined for my lathe.
3/8" 1018 round bar and a 3/8" locking collar.
Got it. I suppose it is to get clearance for the cutter. Yes, you could grind in a clearance angle and have the tool straight but you would have to grind down a long section of the cutter. As long as the keyway actually.Was referring to the angle that seems it weakens the rod.
Thanks, Charlie
Is this is where we remind everyone of the biggest idiot on the internet who broke the crap out of his mill doing an idiot thing because he was an idiot? Not exactly broaching, but the shoe fits:Are you using the mill spindle in lieu of an arbor press
I did it on the lathe using light cuts. Worked perfectly.Are you using the mill spindle in lieu of an arbor press
Trying to decide if I should use my mill or the tailstock on my lathe.Are you using the mill spindle in lieu of an arbor press
The link to the print is on the YouTube video.Yes, very interesting. Is the printout your notes or do you have a link to the source?
Thanks, Charlie
