Given that I can't see clearly right now I need some diversions. I thought about buying a box, but making one for this would just give me time to tinker. I have plenty of 1/4 acrylic that the paper stuck to, and won't release from without a haze from chemical or a chisel. So easy to use it for stuff like this. Needed a mount for my sand blast cabinet for the vibrator/speed control. Glued most of it together from my own homemade brew of glue, but screwed the top on (bottom actually the way it will be mounted).
The glue is the shavings from the plastic either from cutting on the band saw, sanding, or melting. Throw it into a little jar and add acetone. Hours later you have a glue. Yes I could have used C/A. But what fun would that be.
One thing left to do, is bend up a bracket to mount it to the cabinet, and mount it.
My only unknown for the moment is will I need cooling vents, and if I do, can I use a cloth to keep the media out. We'll see.
The cabinet is working real well.
I cleaned up the wheels, many were worse than the rusted one shown. After blasting a light hit with a wire wheel. A lot cleaner than blasting rust all over the place ... I wound up protecting the bearings with duck tape, and a wire to make sure it stayed put. My first one did not and got grit in the bearing.
