- Sep 14, 2014
- 719
No. Sorry, I assumed you had pulled the spindle to replace the belts so would have removed the bearings. . Logan 800 series are unique with "permanently" lubricated double race "pre-loaded" bearings. But most can be opened and re-lubricated. Getting the old soap based grease out can be a PIA. Don't spin them dry, they are that precise. The single bearing by the back gears isn't special. It's a good testament to the quality of these bearings, built to Logan spec, bearings that so many have lasted as long as they have. But at some point the lubricant, or the not cheap bearings, need to be replaced.
You can check your lathe serial number here to see how old it is and see how many, not cheap, parts are available. I suggest you take a little time and read through the topic list here in the Hobby Machinist Logan forum and do a deep dive on anything of interest. I've posted more there about the bearings there if you want more details. And many complaints and comments on them.
If you don't have a manual they can be purchased from Scott and most would strongly advise you have one. As an FYI Scott Logan now recommends way oil for everything. Makes it nice to minimize lubricants needed.
