- Sep 28, 2013
- 4,382
My job today was picking up a non working generator from a friend, cleaning the carb and getting it running. Phones are charging, ice is making and freezers are cooling!
I was about to tap a couple of holes this evening & thought I would give my grandfathers’ old Rigid Supreme Push-Pull tapper a try (just because). Damn thing is pretty handy.
I didn’t have an R8 collet for it, so I just stuck it in the drill chuck & cranked the head up to the sky.
Yep, you still got it down.Yes, I like those also. But they are a young mans tool if you have to do 100 holes. It also makes short work of tapped holes in remote locations, driven by your hand held drill motor.
IIRC, quill down, grip the bottom housing to tap. Release the housing to stop tapping. Quill up, grip the upper housing to unscrew the tap (at higher than tapping RPM). Did I get that right?
I imagine it would drive left hand taps also, if you reverse the driving motor. McMaster used to sell them and replacement collets, certainly in the 90s. I don't see them at McMaster anymore.
Ha! You’re right about that one for sure! I most definitely have a 3/8” R8 collet.Yes, I like those also. But they are a young mans tool if you have to do 100 holes. It also makes short work of tapped holes in remote locations, driven by your hand held drill motor.
PS: If you remove the three-flat-shank from the tool you will see a 3/8-24 tapped hole. Take a long, partially threaded socket head cap screw and install a nut jammed tight at the end of the thread. Shorten the protruding thread as required, cut the head off the screw and you have made yourself a 3/8" straight shank arbor of pretty good steel, easy and cheap. You do have a 3/8" collet, right?
They also made a unit that, at a glance, looks the same, but it mounted "Yankee" type screwdriver bits (1/2 flatted diameter) and was a screwdriver.I have one, but it was not that automatic, you had to pull the shaft out to reverse it. I modified it ... also mine did not have the ability to hold a tap.
But I made a holder.
yep, got it off ebay, and turned it into a tapper. I didn't know they had a tapper. can someone post pics of how the shaft holds taps?They also made a unit that, at a glance, looks the same, but it mounted "Yankee" type screwdriver bits (1/2 flatted diameter) and was a screwdriver.
Does that sound like what you have?
I can't imagine using it safely with slot type fasteners/driver. It's got to be a guaranteed way to damage the finish on the workpiece.
Phillips fasteners, probably OK. It would be easy to rig up 1/4" hex chuck for insert bits and drive any fastener style. Hmmmm?
The tapper came with, IIRC, 6 different capacity collets to drive up to 5/16" taps. The 5/16" collet is very thin in important places and is commonly missing on the used market or broken. Again, IIRC, the tool has a pin across the bottom of the collet chuck and the collets have a slot in the bottom. The knurled nut has an internal taper to squeeze the collet and retain the tap. I'm sorry for continuing to use, IIRC, the chuck shaft on the screwdriver does pull out further than the tapper, but I'm really uncertain about that.yep, got it off ebay, and turned it into a tapper. I didn't know they had a tapper. can someone post pics of how the shaft holds taps?
so I guess you didn't need to pull the shaft down to reverse?
