@dkemppai, almost better off with the loader bucket, where you can set the angle of the bucket and float the arms. That's how I've done it here the few times we've had enough snow to worry about. Definitely slower having to pile it though. And yes, I'm guilty of mowing my lawn yesterday.
Got the cross DRO scale in place. Have secured the wire harness even though this picture was before that. Decided to wait on painting the mounting pieces until I've had some time to run/test it in use.
Old lathes tend to be a little messy but this one was out of control at the change gear end. You can see the cat litter on the floor trying to stay ahead of it. Originally thought one of the headstock shaft seals was leaking, but after a lot of messing around, it looks like the oil was coming from the QCGB, which is an open bottom total loss design. Oil that drips straight down ends up in the tray underneath, but some was getting caught up in the change gear train and splashing up on the belt guard on the left in this picture, then running down that guard to the floor. I'm attempting to caulk a piece of rubberized fiberglass matt, that I originally bought as way cover, to that belt guard so that the oil running down gets redirected into the tray. Maybe I need to be a little more stingy with the oil in the cup for the QCGB too, although that seems potentially troublesome.
Also, while digging through the box with the cross slide scale, I found this long missing "E D C" label for the QCGB. Presumably a victim of the move to the new shop, as the scale was still in the other building. A little spray paint and a few drive screws and it is once again clear which order things go in for the gears. My intiution was always that it should be in reverse order "C D E".
This plate is old and not the easiest to read since it sits below belt height, but this thing does have a nice selection of threads/feeds:
Somehow though I doubt I'll ever use 92 TPI threading.
