- Nov 25, 2015
- 10,032
$20 .. another Chinese kit, you just had to sharpen them.As usual. I made a mess... ...then cleaned it up.
Few more little parts for the crane. These shouldn't have taken this long to make as they did. First step was to predrill a hole to be bored out. Closest thing I could find was a milwaukee hole saw at the hardware store. Wasn't sure how this was going to go. This is some pretty hateful plate to work with. But the drill is carbide toothed. It cut OK. Made it through all 8 plates, running about 50 RPM. Some carbide is chipped/busted, but it got the job done.
Then had to wait for the cheap boring bar set to arrive. It was only $20, and almost wasn't worth that. It saved having to make one from scratch, but had a horrible grind. Luckily the diamond wheel was on the surface grinder, and once that was done it cut pretty well. This little mill drill isn't very stout, so light cuts to finish to size.
View attachment 480973 View attachment 480972
They fit the shafts they're supposed to fit, with a couple tenths clearance. The bore size was spot on. It was a bit tricky to dial the boring head and deal with tool deflection to get it that tight, but it worked out. Maybe I'll feel like doing some assembling and welding after dinner.
The job looks good.
