I'm not worried about that. I'll lose the family jewels on the hook for the power cord long before I hit the caster. Intentional decision to space them wide for stability. I could cut off the outer 1" of the plate as it extends beyond the vertical support plate if I thought that would matter. Ideally I would have used wheels that attach to an axle, which would protrude at least as far, but the local Menards didn't carry anything suitable.looks good except for the caster plates sticking out the back. They are going to hurt when you mis judge and walk past them and your toe hits it. OR you catch something while moving it and it drags it about.
Can you replace it with a screw in caster?
It shouldn't matter. If you did it the other way you wouldn't have any pinching action unless you shaved some off the meeting surfaces.Will it matter once it's mounted?
I take a torch and gently go over the edge when needed, it helps put a finished edge on whatever you have cut. That after sanding ..It usually winds up with a clear polished edge.BTW, on acrylic you may want to anneal it after heroic hole sawing to avoid stress cracking later..
Ramp up to 180 f, hold 1 hour per mm (sounds too slow to me) cool about twice the heat up.
Or, not worry about it
I did some acrylic pressure vessel type stuff a few years back...
Sent from my SM-S911U using Tapatalk
Flame finishing puts a huge amount of stress into the edge. The acrylic will craze much sooner than a polished edge. Annealing will help!I take a torch and gently go over the edge when needed, it helps put a finished edge on whatever you have cut. That after sanding ..It usually winds up with a clear polished edge.
