- Sep 3, 2023
- 374
Re: the added grease zerks:Good job Mike! That should make them last a lot longer.
If they get used. I know mine do not very often, and I know why they should get used.
Could not figure out the pic 3rd from last with the teeth. It didn't look like a band , so maybe I was looking at the results of it running off the wheel?Got cart done for new shop bandsaw.
If they get used.I know mine do not very often, and I know why they should get used.
Brownwood farms?Only when they make cherrie jelly. Company specializes in jams and jellies.
Are those plastic wheels, or cast iron on the cart? if plastic, how much does that bandsaw weigh?
Brownwood farms?
I lived in Elk Rapids for 10 years….
John
Nice, there are some good small producers in that part of the world.American Spoon Food in Petoskey Mi.
I’ve resided all my 52 years in Petoskey/ Alanson
As I frequently say to my wife, "_____________? Hey, I've been there!" [fill in the blank with "Petoskey" in this case. Stayed at the Bay Inn if I remember correctly. Beautiful area, but a little difficult to get to (probably one of the reason's it's so nice).I’ve resided all my 52 years in Petoskey/ Alanson
Really old ones have grease fittings pressed into the sheet metal cap opposite the tapered stud. I suspect that leaving out the grease fitting got somebody a bonus from management.Modified three tie rod ends for the ongoing tractor project. You would think ag equipment would come with grease fittings, but none on old ones which were completely worn out, and none on the new ones either. Set them up on the mill, spot drilled, drilled, and tapped 1/8" npt. Had to grind down a second tap to get high enough on the tapper to get decent thread engagement. Mike
View attachment 473344View attachment 473345
