- Feb 24, 2019
- 956
This isn't a big deal but today I made a converted buck converter tester.
A WHAT??!!
Let me explain.
I have 100 buck converter modules that are capable of being adjustable (as purchased) or modified to deliver a more exact voltage.
What's a buck converter?
A buck converter is a DC to DC voltage converter. Specifically, for my purposes, stepping the voltage down.
The ones I purchased can accept 3-30v and will reduce as low as 3v, no matter how much you feed it.
I only need 3.3-5.1v but I needed something to accept EITHER 12v or 5v and...
This is turning into a long story.
I made a circuit board that is a "shield" for a device similar to an Arduino (but not arduino platform) with a specific purpose. The problem is that purpose can "need" either 12v or 5v pass through. HOWEVER, the microcontroller will fry at 5.5v. So it needs to be reduced to the controller only.
What am I thinking. I can't even explain this in purpose with props. What makes me think I can do it here?
Anyhow, below is the modified buck controller. It needs to have a trace severed and a bridge soldered to keep it AT 5v output. Since I'm doing 100 of them, I wanted to be able to check them quickly because my soldering and trace cutting skills aren't legendary.
You can see on the buck converter where I cut the trace and soldered a bridge.
And on the tester I can just plug the buck converter into the breadboard and it will tell me if I soldered and cut correctly.
It should be noted that these buck converters are TINY.
A WHAT??!!
Let me explain.
