- Oct 16, 2019
- 7,026
Not sure if setting up a new computer for my CNC router counts a making something. Wait maybe it does as I ‘made’ time in the future by not having to wait for ages for the machine to start up.
Jamie, shorten up the cord, that's a hazard and doesn't need to be that long, OR put a zip tie and keep it higher up. Anything that catches in a drill bit, that's long enough, will grab that cord and zap.Finally got around to wiring stock switch on the Walker-Turner drill press… Used existing cord for the switch and bought a 10’ extension cord for the power…
did you ever get the pins out? I know you cut them, just don't remember if you got them out.Getting there, last of the headstock parts cleaning is done.
Closing in on more painting, so got that going for me
Good idea. Will do asap.Jamie, shorten up the cord, that's a hazard and doesn't need to be that long, OR put a zip tie and keep it higher up. Anything that catches in a drill bit, that's long enough, will grab that cord and zap.
That's probably good enough. It's out of the line of fire.Good idea. Will do asap.
EDIT: Tie wraps for now... will adjust length at a later time. Thank you again for the recommendation.
The half of the taper pin in the headstock tapped right outdid you ever get the pins out? I know you cut them, just don't remember if you got them out.
Maybe you could weld a nut to it. The heat will loosen the crud, then you might could lever it out with a pry bar. I would be wary of anything that would alter the location of the locating pin. Every thousandth at that index point will magnify into eighths of an inch at the tailstock. Pretty risky.The half of the taper pin in the headstock tapped right out
As soon as I finish cleaning the plan is to get a steel plate, clamp it down across the ways and use my mag drill to drill and tap. Hopefully I can use a nut with a sleeve over the bolt to remove.View attachment 471117
Think I would use a small end mill with the Mag drill to create a flat spot to start my drill on.The half of the taper pin in the headstock tapped right out
