- Apr 12, 2011
- 3,589
Randy, did you make the aerator as well? nice mods..
Thanks Jeff. No, it is a Everything Attachments purchase. If I had made the aerator I would have made the stands the right way to start with.
Don't need perfectly square cuts. That's just my OCD grumbling about anything and everything...Just out of curiosity, why do you need perfectly square cuts, isn't the support going to be under it, not at the end?
Yes, it is a solid drum and straight line aerating is required. Everything Attachments has a corner turning unit with independent spoon discs, but is was more money and I really didn't need it.Your aerator looks a lot like a King Kutter I was considering. I ended up with a cheapie 40” Agrifab since it was the only one that would fit between some of the trees. I had to go with a pull behind rather than a 3 point mounted one
I had to make each section of the plug disks rotate independently to keep from tearing up the lawn when turning corners. I also added a homemade electric lift to set the plug depth and raise them out of the ground for transport. I haven’t used it for a few years but it’s on the schedule for next spring.
That looks like a fairly big unit. How much area are you aerating? We do about half an acre, but it’s odd shaped. There are lots of corners to turn and many obstacles to go around.
Do you have to lift up when turning as it's one long drum with the spoons attached instead of independent disks? Looks heavy built and like it would work well. I had a 48" agrifab one that worked pretty well after putting 4 JD suitcase weights on top of it! It's one of those attachments that doesn't get a lot of use and while i was happy to have it when i used it I ended up selling it b/c it was a pain to store inside and i got sick of tripping over it - looking at what i paid for it, what i got for it and what they sell for now i should have just left it parked it outside behind my shed in the ding weeds.
