Dogs are fun. Unfortunately, had to put my buddy down a little while ago. These are photos from the last good ride we took in Mid February. This was her absolute favorite chair, ever! Period! No questions asked! Winter or summer, if this thing was out of the garage, she was on it. In the end she couldn't jump up any more, so had to be lifted up, with bad hips and arthritis. But even then it was still her favorite place to be.
They're all one of a kind. She was a special one of a kind!
Decided to actually try to finish a started project. Picked up that arbor press a little bit ago, and ordered a chunk of rack with the right pitch pre-milled into it. Turned out to be almost the same cost as a 1018 blank from mcmaster, but having teeth already milled was a no-brainier. The problem was it was 1.5" sq, and the needed rack is 1.25" square.
After a half a day of messing around in the shop, milled it flat and ground it to about 0.0015" under the nominal groove width. The original was about 25 thou undersized, so this one will be a lot tighter. I'm going to make new gibs from bronze, but they may not even be needed with the new rack fitting so tight. The slot milled in the housing is really nice in clean, looks ground almost. The cover, not so much. I'll probably dust that one flat in the mill and/or surface grinder before fitting the gib.
Sadly, one little 1/4" carbide end mill gave it's life in the processing of saving this old arbor press. You did good little end mill, you did good!
This was a previously used carbide, and it ran a lot of chips out at 9K RPM. Didn't really feel like hogging it all out with a bigger (=more expensive) end mill, so let this little thing chew on it in the CNC. It took a little more than 2.5lbs of steel off. Pretty good life, for the cheapest carbide Enco sold.
And, finally my wife's nemesis, Ebay struck again. Been looking for something like this for a long time now. Finally spotted one that looked good enough to jump on. Other than a few very minor 'tool box' marks (and a light scotch brite of the R-8, it's very clean. No signs of crashing, etc. Been having a hard time justifying one, and didn't dare go the import Chinese route. This used one looked like a good compromise. I think the modern criterion equivalent is about $600 new. I'm WAAAAAY too cheap for that to happen!
