Set up the aquaponic tanks the other day after moving them from the old house.
Todays job was plumbing them in. They are set up with the fish tank high enough to give a slope down to the green tank in the foreground.
Then the sump tanks under what will be the grow beds are also set on a slope but this time leading down the the end sump next to the fish tank where the water is pumped up the fish tank. One pump then gravity feed through all the tanks.
The blue beds and the large green one will be filled with scoria, a volcanic rock that is very rough giving an enormous surface area for the de-nitrifying bacteria to cling to. The water from the fish tank is slowly fed into them then when they are full they automatically drain into the sump drawing oxygen down into the gravel preventing it from turning anaerobic. Those bacteria convert the nitrites from the fish poop into nitrates that the plants use.
However, whats all this got to do with a machining forum?
The first job was machining out a groove for the gaskets to sit tight in
These are for the 2" pipes that pass through the tank walls.
The next job required a 2" hole plug, I used 2x2.5" aluminium disks because I was too lazy to fibre glass in up and wait for it to dry plus it also meant buying a load of resin and hardener for such a tiny repair.
As the hole is in the side of a 30" cylindrical tub (the solids settling filter hidden behind the fish tank) they required bending to shape so I used a large dia chunk of stainless and 2 bits of rod in the vice, gentle squeezing to conform to the shape required.
These will have to be bolted together squeezing a gasket from each side.
A good excuse to make another tool.
I drilled a short length of 6mm stainless rod 5mm
then used a large centre drill to cut the inside edge to a sharp lip
to be used as a punch to cut the holes in the gasket
then bolted together squeezing the wall of the filter and hopefully remaining water tight.
I know there is a good chance water will seep along the thread but theres no pressure and if it does it will soon clog and stop.
Hopefully finalise all the plumbing tomorow then the tedious job washing all the gravel.
I cant wait to get it in full production.
