POTD- PROJECT OF THE DAY: What Did You Make In Your Shop Today?
Today, more cleaning and painting on the new lathe. That's all it's been lately- clean and paint, clean and paint. Degrease this, restore and refinish that. This paint takes three coats by brush to look right on the machine. I don't like painting because I suck at it. I've done a lot and I know a lot about making it stick, but I just can't seem to do pretty. This is turning out pretty good instead. I'm okay with that. First coat on these bits today. I'll keep working my way around cleaning and painting until it's done.
It should be good. I used a bit of polyacrylic adhesion promoter and some isocyanate hardener in a alkyd/oil enamel color blend. I've never seen a direct to metal enamel that has issues with cutting oil. I have no plans to run petri dish coolant, ever. I use Kool Mist sometimes, it has issues with staining nice shiny metals if you're not on top of it, but that's a different thing.
Today... mowed the lawn... organized, just a little bit, the single bay garage... And took some updated photos of the lathe and mill since I did not have those...
Tomorrow they are coming to do some work in there and I needed to get rid of some stuff and clear the side wall so they can install some batteries.
Since I had to move the VW bug, decided to do some work in the interior... baby steps... baby steps...
Tomorrow they are coming to do some work in there and I needed to get rid of some stuff and clear the side wall so the can install some batteries.
Good to see another clean shop, bigger equipment than mine, though.
I’ve been cleaning up a little 1944 Singer 99 hand crank machine for the past few weeks. The machine is done now but the base needed a little TLC as well. One thing that’s always troublesome for me is getting little cushioned feet that I like — a lot of the ones you get now are plastic instead of rubber and they’re also too tall. I don’t like them, and the self-adhesive things are even worse when they (eventually) come off and leave a smeary glue residue all over everything. So, what to do…
Leather is nice but it compresses over time and tends to expose whatever fastener is holding it on. If only I could countersink it somehow…
There was a part of me that said softly “..frank, this has the makings for bad things to happen…” but I went ahead anyway figuring what the heck, I’ve got bandaids upstairs…
I rounded up my nice bit of saddle leather and punched a few discs with the gasket punch. Then I took a sharp brad point spur bit and chucked it into the drill press. This was the almost perfect result — a beautifully clean hole with a nice crisp bottom. All four drilled the same — no tear out, no grabbing, no spinning in my fingers, just a nice clean counterbore.
A few small tacks to hold things in position on we’re good to go.
I still need to clean up the hardware a bit but that won’t take a lot. I’m not aiming for a total restoration, just clean enough to come back into good service as a dedicated buttonhole machine. Thanks for looking!
Oh yeah, almost forgot — here’s what the original feet loot like after 80 years…
I like that epoxied floor!
