- Feb 1, 2015
- 10,121
In the days before unit body construction, the body was added after the engine and drive train were added to the frame. This made for some interesting repair situations. I recall separating a Buick transmission from the engine and using a half a dozen short extensions plus a universal joint to snake a socket up between the firewall and the upper mounting bolts. The thought had entered my mind to cut holes through the firewall.
On a Dodge minivan, the ABS unit was located inside the unibody frame with flared fittings which were virtually impossible to access. Their solution was to use flexible hose with a ss braiding for protection. The braiding was clamped to the steel lines which, along with road salt formed great corrosion couple. The line ruptured on a e -stop; fortunately it was a rabbit and not a kid on a bike. The end of the steel line had a perfect chamfer from the corrosion. Apparently the mechanical engineers in the auto industry don't talk to chemical engineers.
I learned how to swear waiting for a school bus in -20ºF weather but my vocabulary increased greatly working on cars. Not that they are the only issue. In order to work on the brakes on our Nortrac tractor, I have to pull the fuel tank. To remove the fuel tank, I have to pull the rear wheel off. To access the fitting for the fuel return, I have to pull the fuel tank. To adjust the clutch, which the manual says should be done on a regular basis, I have to pull the front end loader frame which means pulling the front end loader off. which means disconnecting the hydraulics.
Clearly, design engineers should have to run through all repair procedures before the design is accepted.
