I use a Snowcaster for less than 3 inch snow. It is great. Just pushing and no lifting.
This is easy but i don't have the right equipment, but new cars are made to be as difficult as possible to fix especially in the electronics department.Wow that was a lot of work. I think the auto makers try and make repairs as hard as they can. So we have to go back to them.
well they are trying to squeeze 100lbs of **** into a 5lb bag.Sometimes you wonder about car designers. I work on imported cars for a living and some just defy logic and wisdom, like having to pull the engine and transmission assembly out the bottom on some Tourags just to change the alternator or starter. Sure they made it come out fairly easily but still it is a 10 hour job. On the starter replacement you have to remove the exhaust manifold and loosen the motor mounts and jack the engine partly out of the removed subframe to get the starter out.
The common comment is that they should make the engineers work on the thing before they release it to the public. Maybe they would change a couple things to make it easier if they could see the whole picture.
NO WAY!!!!The recommended procedure to change the rear brake line on a Land Rover LR3 is to remove the body....
Sent from my Pixel 5 using Tapatalk
Yep, no joke. I am currently working on one that the rear brake line rusted through above the rear axle. I am not removing the body but I have dropped the exhaust to access the heat shields that the brake line is behind so I can find a good spot to cut the existing line and patch a new line onto.NO WAY!!!!
REALLY!!!!
