- Dec 21, 2018
- 2,058
That looks like an expensive way to heat. Where are the pellets made?my heating pallet arraved.
Is that the general brand blue box from Harbor Freight?Done swapping casters for casters/leveling units…and a welcomed decrease in height…
Nice, looks good! I keep thinking about this for my little surface grinder and the tool and cutter grinder. They may go on the same bench/box eventually, they're both similarly dirty pieces of equipment.Yes. I placed a butcher block countertop on it and installed my 9x20 lathe on it...
Pallets are made in serbia, and they are the cheapest way to heat a home, electricity is very expensive, even firewood is more expensive.That looks like an expensive way to heat. Where are the pellets made?
With the de-superheater loop which pre-heats the home hot water, running air conditioning in the summer is cheaper than not. That's not intuitive. Basically heat from the house goes into the hot water tank. It's cheaper to move that heat into the tank than make it all from electricity. Yes, turning off the AC can mean a higher electricity bill. Very counter intuitive...
I paid 385 euros per ton for this A2 known good palles, last year same month i paid 168 euros a ton. We don't have natural gas infrastructure here, propane gas double as well, it is 3.42$ for a US gallon, Gasoline and Diesel are 6$ a US gallon. Fire wood is 80-100$ for a cubic metre, and the monthly income is 10-20% of the ones in the Us.So, 4 metric tons, or about 8815 lbs. at 8250 BTU/lb, that's about 72 million BTU. Let's just guess 85% efficiency, for around 60million BTU into the buildings. (rough numbers here). Do you mind sharing the cost (Maybe converted to Euros or USD) per ton?
In our part of the USA, natural gas is cheapest. Followed by a ground or open loop heat pump (even with relatively expensive power). A lot of us do heat with firewood, but have that for 'free' on our properties. Propane follows that, then heating oil, and finally electricity. When I've looked at the numbers, pellets are between propane and electricity historically. If I had natural gas, that would be my first choice. You may question the heat pump. I ran numbers on all the fuels several years in a row before we built. The heat pump was on par with natural gas, except for the higher up front cost (but with built in air conditioning).
