Without knowing your machine and needs its hard to say but for most hobby shops I think the Superfly or similar fly cutter is the best choice. It will allow you to quickly surface and flatten a work piece up to 6" per pass and larger in multiple passes, and smaller work pieces just as well. You can bring a work piece close to dimensions with this tool too because it can hog off material, trust me. For smaller mills like most hobbyists own the Superfly is a good choice because it cuts with such low HP requirements and it will give you are pretty decent finish. For all these reasons, I think the Superfly or similar fly cutter is a good all around choice. Insert life is actually quite good; I've been using this fly cutter for several years now and am still on the same inserts I started with. Given that almost every work piece I've made since I bought it was squared with this thing, that's not a bad track record.
I think the Sherline tool is a good choice for those of us who need a small tool that can cut ledges. This is an important capability in my opinion. It is also good for when you are squaring smaller work pieces and you don't need a big fly cutter whirling around. I choose it when I need to square a work piece that is an inch or two wide. The inserts have only two usable tips but they last quite a while in a hobby shop. The same insert will cut steels and aluminum, brass, plastic and can last for years when working with soft stuff. It will take a 0.05" deep cut in steel on a Sherline mill; it will go much deeper on a bigger mill.
These tools are not the only ones out there and many folks make their own. I use these because they use inserts that have a good service life and they perform well for me.
