I've also experienced the swirl or lack of a smooth mirror-like surface with fly cutters and have pondered why this is. In my mind, the answer is multifactorial, and since this is coming from MY mind it is naturally suspect. However, this is what I think.
- Fly cutting is not a finishing process. The intent is to obtain a truly flat and accurate surface, which fly cutting does quite well. If you want a finely finished surface, buy a surface grinder or go at it by hand.
- Tool geometry matters because like all machining processes, fly cutting produces cutting forces. Accordingly, we have to use the right insert in the right way. You are using a turning tool and twirling it around, which that insert was not designed to do. Does it work? Of course it does, but are the right edges or surfaces making contact so that the insert works as it should? This is why I suggested that angling your SCLCL tool might not be a good idea because you are then cutting with the nose radius and that greatly increases radial cutting forces and may produce unpredictable or suboptimal results. In contrast, the Superfly has a fixed geometry; you cannot alter the angle of the tool and the angle puts the insert at the desired geometry. The insert is commonly used in face mills so it is optimized to cut with the surface of the insert that makes contact with the work. The insert is a high positive rake insert that I think is intended to reduce tangential cutting forces, which is one reason why the Superfly works well on low HP mills. Bottom line on this is that the tool designers of the Superfly knew what they were doing. Even when taking deep cuts, the Superfly works. On light cuts, the user has to understand that there is a minimal effective cut and that is typically going to be the nose radius plus about a 0.005" or so. Too light a cut and the insert will deflect and you have chatter.
- Tram is always an issue. I would guess that most mills are trammed well enough to function quite well but when fly cutting we are looking at the effect of minute amounts of tram being off. We're talking in the sub-thou range of off. So why does the pattern seem to change when we feed from different directions? I think this is the effect of climb vs conventional milling, and going in a climb direction will typically produce a better finish. I see this effect with my Superfly on my RF-31. I see less of an impact on my Sherline with the Sherline flycutter because that mill is trammed within an inch of its life but I still try to take finish cuts in a climb direction when finish matters.
- Then there are centripetal forces and how they interact with cutting forces. This one is complicated and I still haven't figured out how to visualize how they interact. In my research, I haven't found anything to suggest anyone else knows, either. This is an important topic because it also applies to boring on the mill. I can bore and I can fly cut but do I honestly understand how the cutting forces are interacting? Nope, I don't. The reason this matters is because I think the finishes could be greatly improved with fly cutting if we could get a handle on this. Someday I hope to understand it, or at least hear it from someone who is a lot smarter than me.
A final note on why I think the Sherline fly cutter is an outstanding tool. As mentioned, it is essentially a singe insert tiny face mill. The insert is fixed and mounted in a solid chuck of steel. The insert is not hanging out there at the end of a flexing arm like the typical fly cutter is. Centripetal forces are there but they are minimal. Accordingly, you can take relatively huge cuts with this tool and it will cut well. Because the geometry is fixed and is so solidly supported, the finish is much better with this tool as opposed to more conventionally designed fly cutters. It will put a finish on aluminum that will frost your eyeballs, at least with the unaided eye. Under magnification, you will still see the radial marks of a typical insert but they are much finer than with most inserts. I may seem to make a big deal about this little Sherline tool but I have over 30 years of experience with it and have come to understand why and how it works. Sherline found a way to orient the insert so that it cuts well with one edge oriented vertically (so it can cut to a shoulder); it cuts with the side edge primarily and with light cuts, with the nose radius. However, since the nose radius is very nearly in line with the spindle and it has a mass of steel behind it, deflection is pretty well controlled and that allows a Sherline fly cutter to take lighter cuts and still be fairly accurate when doing so.
Sherline finally woke up and made this tool with a straight shank. This allows us to hold it in a collet instead of a MT1 adapter. This is such a good idea that I'm sure it will sell much better as more people discover this tool. I used mine in a adapter and it worked well but of course, it never dawned on me to just turn the stupid shank down so it didn't have a taper ... Duh! Still, turning it down would have resulted in a much reduced shank diameter so I just decided to buy one with a straight 1/2" shank and will now be happy.
Okay, I'm sure I'll have other thoughts but off the top of my head, this is what I think.
