Mine does not seem to interfere:
The line that goes up to the Z axis does not stay primed. It leaks down and fills with air. Anyone else? Is this a valve issue? I thought about adding a check valve on the outflow port.
Robert
Edit: Adder- it appears that your 3 way connector is mounted backwards. Can you flip it?
R
