What I eventually want to do is take off the fine feed gear box. Once I marked where the
key is, this is simpler as you don't have to worry about the key falling out on you, but even
if you don't mark it, you can loosen the quill lock and raise or lower the quill by hand until
the key slot is pointing up.
I don't think it would be difficult to take off the fine feed gearbox. I think once you get
the coarse feed hub off you just need to remove a snap ring, then remove the 3 bolts holding
it on and I think it will slip off. What I would be interested in seeing is if there is a damaged
tooth on the worm gear. In any event, I have found that just keeping the quill lock on just
a little bit seems to eliminate, or at least greatly reduce the dropping I was seeing. So at the
moment, I'm not in a huge hurry to tear into this, because today I have a working mill with
an annoyance, but if I tear into it, I might not have a working mill...
Why snugging up the set screws doesn't seem to do the same thing for me as the quill lock,
I don't know... Though as Sloth2009 mentioned, maybe the long set screw is too sticky/grabby.
Maybe if the inner set screw had a nylon or brass bearing surface, maybe it would slide more smoothly.
I haven't tried his trick of polishing the end of the inner screw.
