- Sep 1, 2020
- 554
I installed a VFD on my 1440TL without near the level of understanding you have of your wiring. I am sure you will end up with a great install when you are complete. As I skimmed though your notes above I am not sure I follow why your jog should be disconnected? The not on the faceplate saying jog should not be used for gear changes is accurate, when changing gears you want to move the Chuck by hand to allow for smooth gear alignment. The jog function is great when you are fully engaged in a gear and need to turn your part for alignment or measurement. When your lathe is in a very low gear you often can’t turn the Chuck by hand and will need the jog. With my VFD install I actually added reverse jog to the standard forward jog. Can be very handy when you need to move a part.
