In the electrical control and distribution box of the PM-1640TL there was a document describing the electrical system. If anyone has an official electronic copy of it, I would appreciate it if you would post it. Thank you.
In the mean time, I scanned the document and here it is.
Observe "Sheet 2 of 1". So, it was an oriental language speaker that drew the circuits. In some of the oriental languages, the thought process is: "of 2 parts, this is the first".
The diagram is in unfamiliar notation to me. It does not use symbols used in the Pm-1440GT nor the Pm-1340GT documentation of the electrical system.
If these symbols are part of some standard, please let me know, so that I can be sure of the circuit. As it is, I will try to make sense of each symbol first, then, segment the drawing into independent parts: that will make understanding the critical circuit, the safety part of the system, easier to understand.
Wires are numbered with plain numerals, and some wires are labeled with a letter. As I try to explain the circuit to myself, I will use w3 for wire 3 and w11 for wire 11, and so on. An alpha lettered line is its function, not a single piece of wire. Hence wires labeled R are in several locations, indicating the function of that part of the circuit, not a continuous piece of wire.
K1, K2, K3, K4 are relays. The description does not detail to which pin of the relay a wire is attached, only that it is associated with a relay. The relay contacts are represented by what in standard electronics circuits would be a capacitor: like two capital T facing each other, as between w6 and w10.
Normally closed (connected) but opened (disconnected) by energizing the coil is represented by the contact symbol with a stroke across it, as in the symbol between w10 and w12.
The alternating current coil is represented by what electronics engineer would associate with a signal source: a squiggle in a circle, as in the symbol between w12 and [w3-1]. K1 says it is the coil associated with relay 1.
Switches are represented in several ways. There is a single pole, single throw switch SW1 between w2 and w8. It is a simple connect or disconnect switch.
The switch between w0 and w1 is a limit switch. When the end cover pushes up against a roller arm of the switch, the circuit closes (connects).
The switch LS3 and LS4 between w4 and w5 are each a switch that disconnect one circuit and connects to another circuit. In combination, they are part of an either or logic circuit. The switches are physically placed near a cam such that only one switch is active. They are use in the safety component of the lathe is discussed below.
There is a push to disconnect switch, SPB1, between w1 and w2.
There is a push to connect switch, PB1, between w2 and w6.
There are several functions in the diagram. Each function will be discussed, going from left to right:
1. Three phase, 220V power, on wires R, S, and T, common 220V designation, is connected to the motor via fuses F1, (which is composed of three separate fuses), two relays, K1 and K2. Either K1 or K2 (or neither) is activated at any one time. This function is implemented by the physical switch positions, which allows only one of LS3 or LS4 to be active, and further relay logic guarantees this . Damage to the switches, or displacement of the switches could lead to an error in this critical function, except for the additional logic. The circuit at the far right (discussed later) ensures that only one K1 or K2 (or neither) is activated at any time. When K2 is active, S and T are interchanged resulting in the reversal of the motor direction. There is another set of fuses, F2, just after the relays for overload fault. At the motor, the power from R, S, and T is delivered to U, V, W, which is common designation for wires leading out of a three phase motor.
2. Second section of the circuit from the left routes 220V power to the coolant. Relay K3 connects power from R and S to U1 and V1.
[ I ran into a limit of 20 attachments So, this discussion will continue in the next post. ]
