Be careful the little brass plugs #6 will fall out easily. No idea what that is in the pic.
The brass stop in the carriage stop. #6 here. I take my stop off and clean under it after every job. I never leave it on the lathe, just what I do. All I was saying is beware because they will slide out when the stop is not on the lathe.if you are referring to the ball oilers, I did have one fall out on one of my other machines.
Re- wiring in your other thread, now that I see the RPC and the lathe next to each other. You could use this stuff.
HYDROMAXX 3/4 in. Dia x 25 ft. Non Metallic UL Liquid Tight Electrical Conduit Kit with 2 Straight and 2 Angle Fittings Included 4105034025K - The Home Depot
This Flexible, Non-Metallic PVC Liquid Tight conduit, commonly referred to as NM Liquid Tight, flexible conduit, Non-Metallic PVC, Flex PVC and PVC Electrical Conduit is perfect for use in multiple applicationswww.homedepot.com
Between the RPC and the lathe and still be able to sweep up around everything.I take it you'll be running the dryer cord to an outlet in your garage?
John
