- Jun 12, 2014
- 5,058
If you want a manual you can download one from Grizzly under documents, it is the same unit. Many of their SB lathes are made by the same manufacturer. I helped another person install one of these on his 1640, took two of us to lift it and a bear to align. It pays to get it factory installed. I would check on how to use it, I do not recall the specifics on the cross slide lead-screw nut and how to set it up. I have worked with these on a 1440GT. Nice feature, but most people I speak to use them once every couple of years.
Taper Attachment for 13", 14", 16" Lathes - Grizzly Industrial
<h1>SB1263 Taper Attachment for 13", 14", 16" Lathes</h1> <h2>Upgrade your lathe for precise taper machining.</h2> <p>The SB1263 Taper Attachment mounts quickly to the back bed way of your lathe. Accurate tapers can be cut without repositioning the attachment or having to offset the...
www.grizzly.com
