I received and installed Baldor wired but I didn't mount it into lathe yet. I called PM Tech and go to thru all wiring to make sure everything is right before turn it on. At first, the white light is ON but lathe doesn't want to run.
Here are all steps we have done.
1. PM Tech has walked me to check eStop, Brake Switch, Start Switch at the of the bed everything seems correct.
2. PM Tech asked to press Forward / Reverse on the Contact the motor is spending fine. At this time I felt much better.
3. PM Tech asked to reset 2 Circuit Breakers.
4. Finally, PM-1440GT is live and running fine. I noticed the new motor seems smoother.
Again, PM & Tech is awesome. They would do anything to help me to fix defected motor.
