My mill and lathe arrived today. The driver had no issues with the mill, but I thought
he was going to launch the lathe A over T. His lift gate was not large enough, and the
depot had loaded it tailstock first, so he had the heavy end dangling as it came down.
He did however know what he was doing and did get it on the ground safely. The
lathe did shift in the crate during transit, and the lower pallet did not support the
upper pallet very well. The driver noted both on the paperwork before I signed off.
The lathe it self appears undamaged, except the spindle pass through cover is MIA.
I am not sure if the carriage wheel is damaged (first lathe), but it has about half an
inch of play, sliding in allows it to engage and move carriage. When slide out it free wheels.
I did measure the chip pan. I did miss one measurement on the sketch, which is likely
more helpful than the distance from the TS side of the chip pan to the first hole on that
side. The missing measurement is the distance between the inner holes, 35.5"
