yeah, not bad at all for a first attempt. Only thing i would suggest is reduce your step-over for your finishing pass. I've found that around .008 step over with anything over .125 ball end mill produces a surface that's easy to sand out the remaining machining marks. Very useful if you want a polished end product.
ninja edit:
Are you using a z-level finishing technique and dropping it .005 per layer?
Yeah, finish passes are a lot of points so they take a while to generate. you gotta pay to play as the saying goes. Adaptive clearing isn't a great option for finishing, but it got the job done.
I'll open up fusion tonight and see what finishing options there are, if you'd like some input.
there's a checkbox for shallow areas or shallow something or other that will generate additional passes for curved areas, so you can leave a larger stepdown and it will add detail passes only where needed.
