Gunrunner you need to order a set of these for the Z axis hand crank. Bill did you just spit coffee on your monitor? :rofl:
Tom, that is a very nice looking fuel cap. How did you the Infil painting? The threads look great. A few times I have used the powerfeed until I got close then stopped the motor with the gears engaged so I could turn the last bit by hand. Especially on Inside threads into a blind hole. I seam to remember having some un-expected motions on Text when I was using CamBam. I don't think I ever got to the bottom of it before I moved to BobCad.
Looks great Tom. Have you ever cut threads from the back side of the part with the spindle in reverse?
All operations came out as planned except for the text. Not sure what caused the "tails". The letters don't look anything like my drawing.
That looks like ''holding tabs'', could you have put a value in the holding tabs field?
