- Feb 26, 2021
- 515
yes, but the evapo rust can be re-used, the phosphoric acid is a one time brush on or spray on.
I have no problem painting after evapo rust. I clean it off with water, and use tsp before painting or mineral spirits. either works.
No I have not painted over phosphoric acid... good to know. But how do you stop it from being an acid if you just paint over it. I would think you would want to neutralize it.
My understanding is that phosphoric acid doesn't need to be neutralized. Just rinsed well with water. I recommend some surface scrubbing also.
When using phosphoric acid, I pour out a helping, and then dunk the rusty parts in it. Commonly, bubbles will come off the part as the chemical reaction takes place. When the bubbles stop, the part is usually clean. I then pour the phosphate sauce back into the jug. A layer of smut will settle to the bottom of the jug, but the clear fluid on top is still active and ready for its next task. If it goes bad, I haven't found that point. With Evaporust, I've killed many a gallon; it looses effectiveness.
