Oil Can #2
I was greatly inspired by Hackmasters beautiful oil can clone. I decided to do a run of my own with a simpler design. It was suggested that I start a new thread here and not hijack the other thread.
The plan was originally solid brass. I realized that the pump housing would add too much weight so I went with an aluminum pump housing.
I was sort of emulating this original as posted by Hackmaster:
Here is the base pattern:
Its about 3/16" thick at the edge. I will turn it down more when it is brass.
R
Thanks for the kind words. As a new member I'm glad to contribute here.
The screws can be found here:
Fastenal:
http://www.fastenal.com/web/products?term=0179607&searchMode=
Be careful on the price! For some reason the 3/8 x 24 x 1" are $7.91 each but the 3/8 x 24 x 1.25" are $0.27????
Also, you will find that the heads are not centered to the shafts so chucking on the threads becomes necessary.
McMaster has the SS ones:
part number 92240A354
R
EDIT: And really Hackmaster should get most of the credit for the original idea. I had no interest in oil cans until I saw his awesome work!
Fastenal:
R
Thank you very much. I just ordered some.
Another compliment, great work and writeup.
Would you you please give an update on the can works for the cooking oil. Leaking oil on the countertop is a bit of a pet peeve for me.
I will. I am hoping to calibrate it as in x number of pumps per tablespoon.
I see you are from the CLT. Small world!
R
A
Very nice work, my hat is off to you! Isn't there some kind of galvanic corrosion between brass and aluminum though?
Now you tell me!
I assume all dissimilar metals have this. I don't think it will be a big problem in practice. I will let you know in a few years!
R
A
Now you tell me!
R
Haha okay!
I have a homemade book press in the barn, aluminum plates and a piece of brass allthread through it. There is significant corrosion on the entire thing, but the only thing locked up was the allthread/aluminum mating surfaces. But it has been out in a barn in NY (Hot and very humid summers) for 15-16 years so I'm sure that must be part of it.
Sorry if I have made you worried haha, but since it's in a oil can after all I doubt it will be a problem in your situation. If something happens some mylar sheet between the pump body and brass tube will stop all contact. Roll it up into a tube, slip it in the body.
