I found it to be more than "mildly irritating", but then I've never done 22. I still remember the "squeeeeeek" when tapping, and the corners chipping if you milled the wrong direction.
The key is to understand that this stuff will work harden on you if you let it get too hot. A-2 not so much, but D-2 is just waiting for you to go too hard.
Peck drilling, taking light cuts with plenty of coolant, and tapping/reaming slowly with plenty of oil is the way.
It's weird in that I had no issues with 316 or 304 on the Sherline, big problems on the Vevor (at least initially), and I tried 304 on the SB9A I just got working and it cut it with ease. Of course, these are small diameter jobs and I've yet to see how the SB will work with a larger chunk. It's just that I rarely use large diameter SS for anything. No idea if that makes a difference or not...
