- Jun 20, 2024
- 21
Hi all - I'm new to the site. I've been restoring cars all my life and have always wanted a lathe to make parts here and there that are hard to find or no longer made. I recently picked up an EMCO Compact 8 in great condition for $1,200 with a ton of tools, etc. (not sure if that's reasonable, but it seemed to be) and am looking forward to learning! I've never run a lathe, so I'm starting from the ground up. I'm not afraid to ask dumb questions, so here goes:
Wes
- I've cleaned everything up as best I can. I used the oil in the can supplied with the machine to lightly oil all unpainted surfaces after cleaning it. What oil should I buy? Is there a place that would tell me where to oil what on a regular basis?
- I would like to buy replacement belts just to have a set on hand. Is there a preferred brand for those? How would I know which part numbers to buy?
- Are there other maintenance items I should check or do right out of the gate? The machine was allegedly used very little over the last several decades, and only had a few small spots of surface rust that easily cleaned up with 0000 steel wool.
- The 4-jaw chuck is rusted, though not badly. What's the best way to clean that up? Can I use Evaporust, or is that a bad idea?
- As far as I can tell, it came with a full set of change gears, which I understand from reading here are hard to find / expensive, so perhaps I lucked out there. I have no idea how to use them, but would love to learn to make threaded parts after I get the basics down.
- There was another EMCO yellow attachment that came with the lathe. Pardon the ignorance, but could someone tell me what it is and what it is used for?
- Same question for the doodad with the red ball on the end of the handle - does that go with this lathe?
- There are a bunch of other accessories, chucks, etc. Not sure all of them go with the lathe, but they were in the buckets of stuff that came with it. Any help you could offer in identifying what I have would be greatly appreciated.
- Is anything obvious missing? I can always ask the seller to have a look around if so to see if he can find it.
- Any pointers on a good project to start with that would help me get to know the machine? Any good YouTube channels for total lathe newbies?
Wes
