- Oct 6, 2021
- 9
Hello all,
My name is Steve and I’m new to the forum. I’ve been into metal working and fabricating for a number of years, however I’ve just recently entered the machining regime. I purchased a shopfox m1018 a couple of years ago and it’s severed me well, helped get my feet wet and realize I’d need to up my game if I wanted to further my skills. So, I recently acquired a “new to me” lathe from my uncle who’s unable to use it anymore. It’s a Taiwanese import circa 1986 branded Lux Cut. After relocating it to my garage/shop, spending multiple hours cleaning 30+ years of grime, giving it a solid once over, I want to make sure all the fluids (oil and grease) are new and correct before firing it up. I know it ran fine up until about a year ago when he stopped using it.
I’ve searched online and it appears there were many a lathe imported from Taiwan in the 80’s and early 90’s, all of which had subtle changes and multiple branding. I’m trying to track down an instruction manual for my lathe or at least something similar but in the meantime I was hoping someone may be familiar with these family of lathes and be able to offer some direction.
Here in lies the first of I’m sure many questions to follow. What types of oil should I use? There are 3 “oil level windows”, multiple ball oilers, holes under a plate above the transmission gear levers, grease fittings on the shafts in the side gear box, and of course the ways. I keep reading where ISO 68 is the “go to” oil but is all that created equal? I’ve also read where different oil is needed in the apron gear box vs spindle bearings? I’ve read where vactra 2 is the preferred way oil but should it be used elsewhere? Anyway, you see where I’m going. I need direction on any and all lubrications for this lathe.
Thanks in advance and I’m looking forward to being a part of these forums
Steve
Steve
