- Nov 9, 2017
- 222
Hi Guys - back again, I'm starting to play around with machining some aluminum and the cross slide hand wheel seems to have what I think is a lot of slop in it. It turns about 30, maybe 35 degrees right or left before it starts moving the cross slide. This brass(?) nut fits tightly into the hole in the cross slide, so the play must be in the threaded part that the screw drives. Is this nut (what do you call this thing?) worn out, or is this normal for these machines?
